Upper oven will not work Lower oven works fine, checked element Ohms out fine checked power to upper oven element no power to element in bake mode
I am going to assume that the 5 in the model number is incorrect and it should be a S. Here are your parts Parts for KitchenAid KEBS207DWH1 Oven - AppliancePartsPros.comSee the attachment for the tech sheet. I am assuming that it does not work in any mode. Did you check the overheat thermostat (item 37 in section 01). Should be 0 ohms. It kills power to all the elements. Be sure to remove power from the unit when doing this. |
THIS FORUM IS DEAD!!!!!!! |
