donthomp
#1 Posted : Saturday, November 22, 2014 7:00:33 AM(UTC)
donthomp
Upper oven will not work Lower oven works fine, checked element Ohms out fine checked power to upper oven element no power to element in bake mode
#2 Posted : Saturday, November 22, 2014 10:24:35 AM(UTC)
I am going to assume that the 5 in the model number is incorrect and it should be a S.
Parts for KitchenAid KEBS207DWH1 Oven - AppliancePartsPros.com
I am assuming that it does not work in any mode.
Did you check the overheat thermostat (item 37 in section 01).
Should be 0 ohms.
It kills power to all the elements.
Be sure to remove power from the unit when doing this.
File Attachment(s):
KEBS207.pdf (701kb) downloaded 1 time(s).
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Kitchen Aid Electric Rang Power Problem (Oven Repair (including Ranges and Cooktops))
by Guest 3/10/2024 7:24:24 PM(UTC)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Kitchen Aid Model #KBFS20EVMS3 (Refrigerator & Freezer Repair)
by dave kay 3/7/2024 9:50:33 AM(UTC)
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Kitchen Aid KUDS40FVSSO Dishwasher (Dishwasher Repair)
by Guest 9/13/2023 4:38:23 AM(UTC)
Kitchen Aid French door refrigerator KRFF302ESS03 - Freezer (Refrigerator & Freezer Repair)
by dieselgg 8/28/2023 5:31:49 AM(UTC)
kitchen aid fridge (Refrigerator & Freezer Repair)
by Guest 7/25/2023 7:57:36 AM(UTC)
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 8:42:15 AM(UTC)
Kitchen aid gas oven won’t heat up (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2022 4:29:09 AM(UTC)
Kitchen Aid Combo Microwave Door Flops Open Even After Springs (Oven Repair (including Ranges and Cooktops))
by chrison600 11/19/2022 11:33:49 AM(UTC)
Kitchen Aid KRFC300EBS02 (Refrigerator & Freezer Repair)
by Luke_Skyhawker 11/8/2022 3:59:56 PM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
