Timer Will not advance on Permanent Press Cycle, Dryer does not appear to getting as hot as it should, I just replaced the Heating Element, a couple days ago, that was burned out for the first time, and the dryer worked fine, today the timer will not advance. I saw solutions the call for the replacement of the thermal fuse. Would this apply to a dryer that heats that has some heat? It appears a replacement timer is not available. I don't about the sensors, I cleaned them when I was checking for the no heat problem, would a bad sensor on this model keep the timer from working? Thanks
