fatcattara
#1 Posted : Tuesday, September 2, 2014 9:11:00 PM(UTC)
fatcattara
Hi All,
My dishwasher was emitting a burning smell (electrical insulation like) for the last month or more - but it kept on washing. Today, in the middle of a wash cycle all lights on the panel went out and the machine stopped (no circuit breaker had tripped either), and I had to syphon the wash cycle water out. Has the unit got an internal fuse? I'm in the process of opening the bottom panel up, disconnecting the hard wired power (breaker off) and will be looking for burn traces or marks. Any clue what could have burned out?
No leaks on the machine or any other problems - any tip would be much appreciated. :)
fatcattara
#2 Posted : Wednesday, September 3, 2014 2:00:21 PM(UTC)
fatcattara
Today I got to the bottom of it - found the problem and solved it. It was created by a "wannebee electrician " who hooked the dishwasher up. He used compression insulation connectors on one strande and one solid wire. No brainer that you never had a proper connection, he should have used good old marettes! The neutral and hot was burned to a crisp.
After placing a proper connector on the leads the machine was just doing fine - case closed. :) :) :)
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Washer has burning smell (Washer Repair)
by Underhill 6/21/2019 2:26:26 PM(UTC)
Burning smell when using convection oven mode (Microwave Repair)
by landonspop 1/23/2019 9:01:49 AM(UTC)
LG Washer Loud with Burning Smell (Washer Repair)
by bainters 8/24/2018 5:17:59 PM(UTC)
Direct drive washer burning smell- NOT the motor (Washer Repair)
by robmill3r 12/14/2017 7:32:32 AM(UTC)
Gas Dryer Burning Smell, Not Lint (Dryer Repair)
by andymcclure 10/9/2017 2:25:44 PM(UTC)
replaced tub seal, getting burning smell (Washer Repair)
by elocin71 9/4/2017 8:30:02 PM(UTC)
Kenmore 90 Series Burning Smell (Dryer Repair)
by AB81 4/26/2017 6:19:06 AM(UTC)
Burning smell and not pumping out completely - Whirlpool direct drive washer (Washer Repair)
by dwizum 3/16/2017 5:56:53 AM(UTC)
Burning Smell Possibly Electrical (Dryer Repair)
by pauly99 1/24/2017 7:46:14 AM(UTC)
Dryer Burning Smell (Dryer Repair)
by apphelp2888 11/27/2016 5:58:53 AM(UTC)
Kenmore Washer Burning Smell (Washer Repair)
by tfmj 9/13/2016 6:12:10 PM(UTC)
Whirlpool burning smell during agitation (Washer Repair)
by AE472 2/20/2015 6:24:29 PM(UTC)
Washer Motor Burning Smell (Washer Repair)
by CFB33 10/16/2014 7:57:05 AM(UTC)
smoke from starter/plastic burning smell (Refrigerator & Freezer Repair)
by ez211 10/13/2014 8:18:40 AM(UTC)
