Door is leaking on dishwasher, I have replaced the door seal and still leaking, Spray arm looks good no cracks. Vents are clean.
Originally Posted by: Littleking  Door is leaking on dishwasher, I have replaced the door seal and still leaking, Spray arm looks good no cracks. Vents are clean. Door still leaking after replacing new door seal. Check spray wand for cracks but looks good. Check vents to see if it is plugged--- all good.
