jlprsmith@live.com
#1 Posted : Friday, August 8, 2014 4:59:26 PM(UTC)
jlprsmith@live.com
The dryer would run about half of its cycle,then cut off. It was way to hot. After it cooled down we could start it again. I ordered and replaced the Thermal fuse. I still have the same problem. what should I do now. thanks.
fairbank56
#2 Posted : Saturday, August 9, 2014 6:04:22 AM(UTC)
fairbank56
Groups: Expert
Check for excessive lint buildup in all internal and external ducting. Be sure to check inside blower housing as well. Blow out lint in motor. Make sure there is no heat during air fluff cycle. If there is, then heater coil is probably grounded. If ok and ducting is all clear, then I would replace the operating thermostat. This regulates the heat, assuming air flow is correct (no blockage, no leaks).
Whirlpool 3387134 Dryer Cycling Thermostat - AppliancePartsPros.com
Eric
jlprsmith@live.com
#3 Posted : Saturday, August 9, 2014 11:46:11 AM(UTC)
jlprsmith@live.com
What is the operating thermostat? Is it the same as the cycling thermostat?
fairbank56
#4 Posted : Saturday, August 9, 2014 12:24:36 PM(UTC)
fairbank56
Groups: Expert
Yes, see link provided for part.
No Heat problem on electric dryer (Dryer Repair)
by sandylittle314 12/27/2014 1:14:15 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
Heat Problem (Dryer Repair)
by Mariner109 9/16/2013 4:17:44 PM(UTC)
Dryer heat problems (Dryer Repair)
by gmckinley 6/14/2013 8:46:54 PM(UTC)
kitchenaid elec range heat problem (Oven Repair (including Ranges and Cooktops))
by otto208 1/26/2013 6:13:52 AM(UTC)
Oven Heat Problem (Oven Repair (including Ranges and Cooktops))
by Ironcowboy 11/1/2012 3:20:17 PM(UTC)
intermittent dryer heat problem (Dryer Repair)
by busterhead 10/19/2012 2:28:25 AM(UTC)
Roper Dryer No Heat Problem (Dryer Repair)
by schmocker 7/16/2012 1:17:00 PM(UTC)
gas dryer heat problem (Dryer Repair)
by SPRISL 7/6/2010 10:53:01 AM(UTC)
by fire100 10/22/2009 10:02:42 AM(UTC)
Questions on fixing Whirlpool gas dryer no heat problem (Dryer Repair)
by yzhong 8/2/2009 8:29:05 AM(UTC)
high heat problem (Dryer Repair)
by mm6018 7/13/2009 6:42:47 PM(UTC)
by ribwholesalers 7/8/2009 1:44:21 PM(UTC)
by pep33 7/7/2009 3:08:36 PM(UTC)
by wtelwe 2/10/2009 6:42:48 PM(UTC)
