sandylittle314
#1 Posted : Saturday, December 27, 2014 1:14:15 PM(UTC)
sandylittle314
I have an Inglis Whirlpool electric dryer.Model #IES5000RQ1. One day it started to go from cold to hot to cold in different cycles. For a couple days I noticed a burning smell & the dryer got really hot. After that it dried fine till a week ago it stopped getting hot at all. Only blows cold air. There's was no lint blockage so I ordered & replaced the thermal fuse hoping that's all it was. Still not warming up. What would be the next step? I'm a single mom & my son is serving in Afghanistan right now so I'm trying to repair it myself. Any help would be greatly appreciated:)
#2 Posted : Sunday, December 28, 2014 2:03:31 AM(UTC)
Parts for Whirlpool IES5000RQ1 Dryer - AppliancePartsPros.com
The next step would be to check the heating coil.
Note the thermal fuse would have also shut the motor off.
Also it would not hurt to check the power.
The heating coil requires the full 240 volts.
There is a way to do this without actually having to measure it with a meter.
Set the unit to timed dry with the door closed.
The timer should advance as it also uses the 240 volts.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
IES5000.pdf (156kb) downloaded 4 time(s).
