Have Beverage-Air Mini fridge. Evap Fan working, But no compressor Fan working. The compressor is not working also.Compressor takes R-12. Got ohms on compressor. 5 at bottom 2 leads, got 4 at bottom and left,4 at bottom and right.
Got the Compressor fan running after I bypassed the (Bad) thermostat. Can I use any refrigerator thermostat To see if compressor will work. If not, Is there a way to check without ohm meter?
I cannot find info on this unit but perhaps the following should help. Below is a link with info on how to check fridge parts. How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.comNote that even if a compressor's windings check out OK, it does not mean that the compressor is good as it may have mechanical problems. [COLOR="Blue"]Got the Compressor fan running after I bypassed the (Bad) thermostat. Can I use any refrigerator thermostat To see if compressor will work.[/COLOR] I do not understand the above. You bypassed the control thermostat so the compressor should have come on when the condenser/compressor fan came on. [COLOR="Blue"]If not, Is there a way to check without ohm meter?[/COLOR] Sorry but not sure about the above. Perhaps see the link. |
THIS FORUM IS DEAD!!!!!!! |
