Hello, I have a 6 month old Haier mini fridge that has stopped cooling. Both fans are still running fine and I'm guessing a relay of some sort has stopped working. I'd appreciate some tips, thanks! Graham
Sorry but I cannot find any tech info on this unit so cannot be of much help.
I would get it repaired under warranty.
I did find some sales info on it and it says that the unit does not have a compressor so I think it has a peltier device. This is a device which uses two connected metal plates. When DC voltage is a applies one side gets cold. Many of these have a thermal fuse to prevent them from overheating so perhaps that has blown. Could also be that the DC power supply is kaput.
I wish I could be more helpful but I do not have a link to Haier info. |
THIS FORUM IS DEAD!!!!!!! |
