buddha131
#1 Posted : Sunday, August 3, 2014 2:08:50 PM(UTC)
buddha131
Have Beverage-Air Mini fridge. Evap Fan working, But no compressor Fan working. The compressor is not working also.Compressor takes R-12. Got ohms on compressor. 5 at bottom 2 leads, got 4 at bottom and left,4 at bottom and right.
buddha131
#2 Posted : Tuesday, August 5, 2014 1:58:33 PM(UTC)
buddha131
Got the Compressor fan running after I bypassed the (Bad) thermostat. Can I use any refrigerator thermostat To see if compressor will work. If not, Is there a way to check without ohm meter?
#3 Posted : Wednesday, August 6, 2014 1:14:09 AM(UTC)
I cannot find info on this unit but perhaps the following should help.
Below is a link with info on how to check fridge parts.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note that even if a compressor's windings check out OK, it does not mean that the compressor is good as it may have mechanical problems.
[COLOR="Blue"]Got the Compressor fan running after I bypassed the (Bad) thermostat. Can I use any refrigerator thermostat To see if compressor will work.[/COLOR]
I do not understand the above.
You bypassed the control thermostat so the compressor should have come on when the condenser/compressor fan came on.
[COLOR="Blue"]If not, Is there a way to check without ohm meter?[/COLOR]
Sorry but not sure about the above.
Perhaps see the link.
Avanti Mini Fridge Not Cooling (Refrigerator & Freezer Repair)
by David1988 12/28/2014 12:07:44 PM(UTC)
Haier mini fridge not cooling (Refrigerator & Freezer Repair)
by gillfinn 12/18/2012 2:24:13 PM(UTC)
Igloo FR834 Mini Fridge not cooling and compressor HOT (Refrigerator & Freezer Repair)
by pentester101 7/25/2012 11:21:09 AM(UTC)
