colbey
#1 Posted : Friday, July 11, 2014 4:55:38 PM(UTC)
colbey
I did search for posts about intermittent heat, but all I found was one for no heat (for Estate dryers). If I simply missed a relevant post, I apologize for double-posting, and please direct me to the post. Otherwise...
This could be Model #EED4100WQ. Couldn't quite make it out when I was upstairs and didn't have my glasses. Sorry. I can get it if needed, but they seem pretty much the same.
So, there is intermittent heat. My mother normally uses/used a certain cycle and sometimes the clothes dry fine, and sometimes they don't dry and she says they don't even feel warm. I always use a different cycle and hadn't noticed a problem. She switched to using yet another cycle and didn't have a problem...until today. When one load dried and one didn't, and the one that didn't apparently didn't have any heat. So the problem could be getting worse.
I read about what to do/check, and here's what we know:
The dryer vent was cleaned out--from the outside of the house, we went in with a vacuum and cleaned it out. There did not appear to be any build-up, though. We haven't cleaned the hose at the back of the dryer (yet) but because there was no build-up, and we can feel plenty of air coming out when operating, it doesn't seem likely that that part is clogged and causing the problem. (Also, it's intermittent.)
Circuit Breaker/s -- doesn't seem likely, as it runs okay (1 breaker, I guess) and the "no heat" is intermittent, so the 2nd breaker must be fine.
Yes, it's in a closet. But this is a recent issue and, again, it's intermittent, so being in a closet must be fine/it must have enough ventilation/space.
So it's down to a thermostat, a fuse within the dryer (?), a heating element (there may be more than one?), a thermal limiter (no idea what this is), or a burnt wire. There has been no burning smells, so it doesn't seem likely it's the last one.
Of the other possibilities, which could cause an intermittent problem?? Or is it something else that I haven't been able to come up with?
Related questions --
1) I'm pretty sure my dad has an Ohmmeter, but does it have to be a certain kind? I haven't fully read that post about testing for continuity, but I will. Although first I need to know where those parts are and how to get to them.
2) Of those possibilities (of what could be wrong), do you (APP) carry the part/s?
3) Is it something that I could replace/repair on my own?
3b) If so, where can I find a schematic/diagram to guide me?
Thank you for any help provided!
colbey
#2 Posted : Friday, July 11, 2014 5:10:33 PM(UTC)
colbey
I was scanning thru some of the more recent posts (it's been a few weeks since I searched before) and found this one:
http://forum.appliancepartspros...nly-heats-one-cycle.html
It's a Whirlpool, and it isn't exactly intermittent heat--no heat on one cycle, but heat on another (whereas we have intermittent heat within a cycle). But fairbanks56 responded that their problem was a faulty timer. Could that be our problem?? I hadn't come across that possibility in any of the stuff I've read.
#3 Posted : Saturday, July 12, 2014 3:22:00 AM(UTC)
Parts for Estate EED4400WQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
I will try to answer your questions.
The biggest hurdle here is that the problem is intermittent so trying to troubleshoot the problem will be difficult to say the least.In my experience intermittent problems never occur when your are at the unit ready to troubleshoot. Also often just moving the unit a little can make it operate correctly.
I would unplug the unit and check the line cord connections at the terminal strip at that back of the unit. make sure all 3 connections are tight and that there is no signs of overheating. Check the prongs on the line cord for signs of arcing and that they are nice and clean.
If OK
You could check all the wiring in the heater circuit path for a loose connection. This will be a fair amount of work so if you do open it up also check the belt, the rear support rollers, the idler wheel, the front drum supports etc. You may as well give it an overhaul and at least know what a total cost to do this would be.
I would probably just replace the timer as it is the most likely cause but this is a gamble.
[COLOR="Blue"]She switched to using yet another cycle and didn't have a problem...until today. When one load dried and one didn't, and the one that didn't apparently didn't have any heat.[/COLOR]
This points to a timer problem.
[COLOR="Blue"]We haven't cleaned the hose at the back of the dryer (yet)[/COLOR]
I would check this just to be sure that it is OK.
Also in the circuit is the centrifugal switch on the motor and timer contacts A-B.
[COLOR="Blue"]So it's down to a thermostat,[/COLOR]
Possible
[COLOR="Blue"]a fuse within the dryer (?),[/COLOR]
There are actually two thermal fuses in the unit.
One is called a Thermal Fuse it kills power to the motor.
The other is called a Thermal Cut-off it kills power to the heater.
It will not be either of theses as they are fuses and once blown stay blown.
[COLOR="Blue"]a heating element (there may be more than one?),[/COLOR]
There is only one main heating element.
There is another heating element but it is built into the control/operating thermostat. it is turned on when you use a low heat cycle. it adds heat to the thermostat which causes it to open more often resulting in less heat from the main heater.
[COLOR="Blue"] a thermal limiter (no idea what this is),[/COLOR]
Could apply to either a thermal fuse or hi-limit thermostat.
Does not really matter as this term is not used in this unit.
[COLOR="Blue"]
or a burnt wire. There has been no burning smells, so it doesn't seem likely it's the last one.[/COLOR]
I agree with you but could be a loose connector.
[COLOR="Blue"]1) I'm pretty sure my dad has an Ohmmeter, but does it have to be a certain kind?[/COLOR]
No, as long as you know how to use it. Though I am not sure it will be of any use as the problem is intermittent.
See the parts breakdown. Note that if you click on a part's picture or description a new page will open with more info about that part. There are even some videos.
[COLOR="Blue"]2) Of those possibilities (of what could be wrong), do you (APP) carry the part/s?[/COLOR]
I did look at your added post and fairbanks56 has identified the most likely cause. I would check the connectors at the timer to be sure they are OK/tight. Also the connections in the heater circuit path. If all OK then I would replace the timer.
You should be able to do this if you have some DIY skills.
[COLOR="Red"]Be sure to unplug the unit when working on it.
240 volts is lethal.
[/COLOR]
[COLOR="Blue"]
3b) If so, where can I find a schematic/diagram to guide me?[/COLOR]
See the above info.
File Attachment(s):
EED4400.pdf (216kb) downloaded 37 time(s).
colbey
#4 Posted : Saturday, July 12, 2014 7:34:12 PM(UTC)
colbey
Thank You!
that is the correct model number -- EED4400WQ0. i checked.
i did a load later last night and one again today. dried them on the cycle i always do; both didn't dry. took 2 times for both loads. so the problem is "spreading."
so...just like my truck won't "do" whatever is wrong when i take it to the mechanic. of course not, lol.
good point. yesterday, the top cover was rattling. that'd never happened before. i finally found a spot to press to get it to stop, but you're right--if this is a loose connection, moving the dryer might bump it back where it should be. although i would hope i could still tell it is loose with an inspection.
line cord
you mean the...power cord, right? just check the power cord itself, and where it connects? that i can do.
hmm. i found a great page last night on replacing the heating element. that will be..."easy." at least the instructions (w/ pics) seemed very clear. i'll have to look at the diagrams you posted and some others i found to see where this other stuff is. when you say "check" this stuff, will it be fairly obvious if there's a problem? otherwise i might not know what i'm looking for.
okay. then the "spreading" that happened with the last 2 loads probably also points to this.
that's the part that i haven't found discussed much yet. one page where a repair guy went thru, in detail, how he would diagnose/check a dryer problem covered much of the other things i'd mentioned, then got to the timer and he said if everything else is okay, it could be the timer but i rarely see that as the problem. so that's a little weird.
i just checked a schematic i found and the timer is right at the top (in a different whirlpool model). basically, it's right behind the dial where you chose a cycle. and that is what i was wondering about--since it was intermittent; since it was (at that time) only affecting one cycle; and now with the rattle that started yesterday--that it was something right there by the selector knob. some loose connection or something. and the timer is right there. (at least in the other model.)
oh--just checked your parts page. same spot. and it's only...$100! lol
duh. good point.
i told my mom that it's likely the timer, and it's cost, so she can think about it and have a better understanding of what a repairperson might charge if they want to go that route.
but it sounds like the best way forward, as you said, is to check the connections for the timer. and the heating element. because, obviously, if the heating element is simply bad, then there wouldn't ever be any heat. but if a connection is loose...
so, off to find instructions on checking the timer connections and/or replacing it.
and i shouldn't need an ohmmeter! LOL. (i think my dad just has a battery tester--for small household batteries--and i doubt that's what i'd need.)
thank you very much!!
#5 Posted : Sunday, July 13, 2014 2:04:02 AM(UTC)
It will probably end up costing a minimum of $200.00 to get a repairman in to replace the timer.
[COLOR="Blue"]line cord
you mean the...power cord, right? just check the power cord itself, and where it connects? that i can do.[/COLOR]
Yes and yes
[COLOR="Blue"]will it be fairly obvious if there's a problem? otherwise i might not know what i'm looking for.[/COLOR]
I cannot say depends how lucky you are.
With luck it now is not an intermittent problem.
So if all else is OK then here is how I would go about troubleshooting the timer.
You will need a meter.
Run a cycle where you get no heat.
Open the door so the unit stops.
Unplug it.
Then check contacts A to B on the timer, should be 0 ohms.
If not the timer is bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
There is a good STICKY at the start of this forum about it's use
colbey
#6 Posted : Tuesday, July 15, 2014 2:52:41 PM(UTC)
colbey
okay. i explained things to my parents and they momentarily freaked out. my mom wanted to call a repairperson in, and my dad just wanted to buy a new dryer. i waited a bit, then convinced them to at least try 1)looking at the timer and seeing if any wires were loose, and then 2)replacing the timer. i said that if replacing it doesn't work, then they can buy a new dryer--likely from the place where they bought this one, which also sells used appliances. i said that place would probably give them a store credit towards a new dryer of AT LEAST the cost of the timer, because the dryer is in great shape and they'll be able to fix it in no time. so they'll be out nothing, for trying a new timer.
anyway....my dad and i pulled out the timer. nothing was loose. he didn't want to do the thing of running a cycle until there was no heat, so there's no way to know it WAS having the problem. i unplugged the dryer; and removed the 2 wire harnesses. checked the reading for points A to B and it did NOT read 0. the needle didn't move at all. so that either means the timer's bad, or i did something wrong--like, i shouldn't have disconnected the wires. but it didn't look like i could get a contact with the ohmmeter without removing the harnesses. i just told dad the timer was bad and they ordered a new one.
i also pulled off the vent hose and it was clear. to make sure, dad took it and vacuumed it out. the line cord looked good on the plug end. i didn't pull off the other access covers and check the other end of the line cord or the heating element. dad wanted to do this stuff RIGHT THEN, and i only had a small amount of time. so i'll check those when i put in the new timer.
but -- (there's always a but, right, lol). the timer isn't the one in the video i watched. btw, the video, and the Q&As on the parts page were VERY helpful/informative. i had no idea they were there. i did post a comment for the video on the parts page, but i have a question.
the timer in our dryer IS #10185970--it was labeled on the timer. but it has 9 wires into it, rather than the 6 in the video. 7 of them were in 2 harnesses and came off just as in the video. but 2 wires go into a small harness/clip that's in the middle of the "underside" of the timer. the picture of the underside on the parts page is correct--if you look at it closely, you can see the 7 connections on the side, grouped in 3 and 4. and in the middle is a small white square (it has a red band on it)--the other 2 wires clip in there on a small plastic piece. i believe those wires were black and white (1 of each, not mixed).
i cannot get that clip out. it looks like there is a tab on the top that needs to be pressed down to allow the wire clip to slide out of the white 'box.' but it doesn't move--my dad even used a small screwdriver to press on the tab-looking part while i pulled on the other piece. it didn't budge.
how do i get that clip off??
colbey
#7 Posted : Tuesday, July 15, 2014 10:22:50 PM(UTC)
colbey
another update --
i realized i probably needed to have the dryer in the middle of a cycle to check the timer continuity?? we left the dryer mostly apart, but i put the timer knob back on and turned it to the middle of a cycle (heard it click and all). set the ohmmeter to RK1 (or whatever--the lowest for Ohms) and made sure that when i touched the leads, it went to 0.
then i checked the A to B connection, and the needle didn't move at all. i know it probably can't matter where i touched the leads to the prongs, but i tried it all over. the needle didn't move at all.
i tested it in each of the 3 cycles (using the knob to move to each one, and hearing the "clicks" as it moved). no movement at all.
from the schematic, it looked like there's supposed to be a circuit from C to H, so for kicks i checked that. still nothing.
i even checked the wires themselves, in the harness. still nothing, which is probably good, because maybe that means i wasn't a total idiot--the dryer was still unplugged, otherwise maybe the ohmmeter would've exploded in my hands, i would've blown backwards to shatter the wall mirror, and instead of being here posting, i'd be on my way to the hospital. or morgue.
and i did get the other wire harness/clip off. yes, one wire was black; the other white with a black or blue stripe. there was a tab, but rather than pushing down on the tab, i had to slide a tiny screwdriver under the white box on either side of the tab and push up. so that came off. then i rechecked the A to B circuit, but still nothing.
#8 Posted : Wednesday, July 16, 2014 3:24:09 AM(UTC)
Yes it looks like a bad timer.
A to B should be closed mid cycle of any heating cycle.
colbey
#9 Posted : Thursday, July 17, 2014 7:10:59 PM(UTC)
colbey
solved!
we got the new timer and put it in. i checked for any other damage or loose connections when i had the back panel off. didn't see anything. after install, there was heat for 2 loads of laundry, with mom using the cycle that had completely stopped having heat.
only one strange thing--just before we put the new one in, dad decided to check the new one for continuity since the meter was right there. on the new timer, the needle did NOT move when checking from A to B. then he checked from C to H, and still nothing. then he was just moving the leads around, and we got a zero Ohm reading from B to C.
we looked at the schematic, and there is a route there, but it's a bit "different" so i didn't really pay any attention to it. (btw, just so you know for others, there was a wiring schematic tucked into the back of the dryer, next to the timer. it's the same one you attached here.)
when we tested the old timer, from B to C, we also got a 0 Ohm reading. which kinda freaked me out.
i don't understand it, and i'm only telling you because maybe you'll understand it and maybe it will help someone else in the future.
at any rate, with the new timer, there is heat in all 3 cycles. so far, lol. i'm holding my breath just a bit because it WAS intermittent, at least when i started this thread. but i'm pretty sure we got this fixed.
thank you SO MUCH for all your help! you've been awesome!!
Maytag MEDC200XW1 - Intermittent heat and no buzzer (Dryer Repair)
by Lemarac 1/9/2019 4:09:17 PM(UTC)
electric dryer intermittent heat (Dryer Repair)
by wags1970 7/11/2017 9:31:33 AM(UTC)
gas dryer with intermittent heat (Dryer Repair)
by highpoint 1/21/2017 12:14:48 PM(UTC)
Intermittent Heating (Dryer Repair)
by lccent 8/7/2015 9:19:56 AM(UTC)
Intermittent heating. Now none. (Microwave Repair)
by bstruss 2/23/2015 6:29:10 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
LG electric dryer Intermittent Heat (Dryer Repair)
by Saurin 10/2/2013 7:41:23 PM(UTC)
by greg.od11@gmail.com 8/21/2013 3:29:48 PM(UTC)
Gas Dryer Intermittent Heat (Dryer Repair)
by FranDaMan 7/4/2013 6:53:18 PM(UTC)
by gvel 5/19/2013 3:38:09 PM(UTC)
Gas Dryer - Intermittent heat, checked coils and igniter (Dryer Repair)
by nevets 11/18/2012 6:14:02 PM(UTC)
by rcady52 10/26/2012 12:03:54 PM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
Maytag Dryer Intermittent Heat (Dryer Repair)
by jayjaysin 6/24/2012 4:59:26 PM(UTC)
Whirlpool LGQ9857LW0 Intermittent heat (Dryer Repair)
by deanm11 6/17/2012 4:08:12 PM(UTC)
