Parts for Estate EED4400WQ0 Dryer - AppliancePartsPros.comSee the attachment for the wiring diagram.
I will try to answer your questions.
The biggest hurdle here is that the problem is intermittent so trying to troubleshoot the problem will be difficult to say the least.In my experience intermittent problems never occur when your are at the unit ready to troubleshoot. Also often just moving the unit a little can make it operate correctly.
I would unplug the unit and check the line cord connections at the terminal strip at that back of the unit. make sure all 3 connections are tight and that there is no signs of overheating. Check the prongs on the line cord for signs of arcing and that they are nice and clean.
If OK
You could check all the wiring in the heater circuit path for a loose connection. This will be a fair amount of work so if you do open it up also check the belt, the rear support rollers, the idler wheel, the front drum supports etc. You may as well give it an overhaul and at least know what a total cost to do this would be.
I would probably just replace the timer as it is the most likely cause but this is a gamble.
[COLOR="Blue"]She switched to using yet another cycle and didn't have a problem...until today. When one load dried and one didn't, and the one that didn't apparently didn't have any heat.[/COLOR]
This points to a timer problem.
[COLOR="Blue"]We haven't cleaned the hose at the back of the dryer (yet)[/COLOR]
I would check this just to be sure that it is OK.
Also in the circuit is the centrifugal switch on the motor and timer contacts A-B.
Circuit Breaker/s -- doesn't seem likely, as it runs okay (1 breaker, I guess) and the "no heat" is intermittent, so the 2nd breaker must be fine.
[COLOR="Blue"]So it's down to a thermostat,[/COLOR]
Possible
[COLOR="Blue"]a fuse within the dryer (?),[/COLOR]
There are actually two thermal fuses in the unit.
One is called a Thermal Fuse it kills power to the motor.
The other is called a Thermal Cut-off it kills power to the heater.
It will not be either of theses as they are fuses and once blown stay blown.
[COLOR="Blue"]a heating element (there may be more than one?),[/COLOR]
There is only one main heating element.
There is another heating element but it is built into the control/operating thermostat. it is turned on when you use a low heat cycle. it adds heat to the thermostat which causes it to open more often resulting in less heat from the main heater.
[COLOR="Blue"] a thermal limiter (no idea what this is),[/COLOR]
Could apply to either a thermal fuse or hi-limit thermostat.
Does not really matter as this term is not used in this unit.
[COLOR="Blue"]
or a burnt wire. There has been no burning smells, so it doesn't seem likely it's the last one.[/COLOR]
I agree with you but could be a loose connector.
Of the other possibilities, which could cause an intermittent problem?? Or is it something else that I haven't been able to come up with?
Related questions --
[COLOR="Blue"]1) I'm pretty sure my dad has an Ohmmeter, but does it have to be a certain kind?[/COLOR]
No, as long as you know how to use it. Though I am not sure it will be of any use as the problem is intermittent.
Although first I need to know where those parts are and how to get to them.
See the parts breakdown. Note that if you click on a part's picture or description a new page will open with more info about that part. There are even some videos.
[COLOR="Blue"]2) Of those possibilities (of what could be wrong), do you (APP) carry the part/s?[/COLOR]
I did look at your added post and fairbanks56 has identified the most likely cause. I would check the connectors at the timer to be sure they are OK/tight. Also the connections in the heater circuit path. If all OK then I would replace the timer.
3) Is it something that I could replace/repair on my own?
You should be able to do this if you have some DIY skills.
[COLOR="Red"]
Be sure to unplug the unit when working on it.
240 volts is lethal.[/COLOR]
[COLOR="Blue"]
3b) If so, where can I find a schematic/diagram to guide me?[/COLOR]
See the above info.
