I have a GE Model #GSS25JFMBCC refrigerator in which the evaporator coil freezes. The defrost heater and thermostat measure continuity. The thread by Gene suggests that I replace the control board and both freezer thermistors. My problem is that I can't find the thermistors on the diagram. How do I locate the defrost thermistors?
The evaporator thermistor, aka a temperature sensor, (the one I recommend to replace together with the main control board) is shown as #241 on the diagram. It is located on top of the evaporator. All thermistors in the refrigerator are identical and are interchangeable. - The thermostor Part number: AP3185407
