AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Kitchenaid KRFF305ESS00 refrigerant lines going into body NOT to evaporator
Refrigerator Model: KRFF305ESS00 Serial: K65014902 Long story short I pressurized the system to 100 psi with argon (I'm a welder so it's what I have on hand). I can hear the leak coming from the front of the refrigerator when I put my ear against the bottom shelf where the door refrigerator door screws into. I started to cut out the foam in the back to trace the lines one goes to the left and the other goes straight. It's going to be a pain to cutout the foam so I wanted to get some opinion on how to get to whatever is at the end of those lines that's leaking. What I've done so far:
- Soap test everything accessible at 3 psi - no leaks
- Compressor lines
- Evaporator lines
- Condenser and lines
- Bought the service manual/parts list online ($16)
It only shows the compressor and filter dryer... these two lines I'm interested in are omiited!
- Searched online for diagrams/posts/etc that describe the internals of what the refrigerator might have outside the condensor/evap inside the body...
- Cut out a part of the back panel to follow the line back to the leak (where I currently am)
- Signed up at AppliancePartsPros and did some searching for my topic - No real results but might be my search terms...
- Posted this topic hear to see if someone knows what those lines are going to
Images of the lines I'm referencing below. [img=https://imgur.com/a/IwZhtNm]Kitchenaid refrigerant lines[/img] another link to imagesIf you can identify them and let me know the easiest way to get to the end I would highly appreciate it. Thanks! Tre Edited by user Sunday, January 15, 2023 9:21:22 AM(UTC)
| Reason: Not specified
Update. Turns out to the the Yoder loop. Not worth the time to fix since it will damage the door. There’s an alternative where you get a small heater wire and run it through the lineset.
Going to look into that it might just let it run wild without one. I’ll update this in a few months with the solution I went with.
Tre
