My dryer wont heat. I was told that the thermal fuse was bad. I replaced it,still wont work. So I replaced the heating element, it still wont work. the drum turns. Please help.
Groups: Expert
When set to timed dry cycle, does the timer advance? If not, check that you have 240vac at dryer receptacle. If you do, unplug dryer, open the small panel at upper middle on back of dryer and check the power cord connections to see that they are clean and tight. No burning/melting of terminals or wires.
Eric
Check your specific model number, but I just went through this with mine, and it was the high-limit cut out -- different from the thermal fuse.
checked for power from circuit panel to dryer, all good. have replaced all electrical elements, and still doesn't heat. blower runs fine, cold air from exhaust. please help. model: EED4400EQ0 Whrilpool Dryer
Thanks. Ed
Groups: Expert
Can't help if you don't answer the questions. When set to timed dry cycle, does the timer advance??? If it doesn't, then the motor switch is likely the problem. If it does advance, then the timer is likely the problem since you've replaced all other components in the heat circuit. The timers on these dryers are absolute junk and fail often. Whirlpool W10185970 Timer - AppliancePartsPros.comEric
