ammo1md
#1 Posted : Friday, February 14, 2014 10:38:35 AM(UTC)
ammo1md
My dryer wont heat. I was told that the thermal fuse was bad. I replaced it,still wont work. So I replaced the heating element, it still wont work. the drum turns. Please help.
fairbank56
#2 Posted : Friday, February 14, 2014 12:15:04 PM(UTC)
fairbank56
Groups: Expert
When set to timed dry cycle, does the timer advance? If not, check that you have 240vac at dryer receptacle. If you do, unplug dryer, open the small panel at upper middle on back of dryer and check the power cord connections to see that they are clean and tight. No burning/melting of terminals or wires.
Eric
jeffinsgf
#3 Posted : Saturday, February 15, 2014 9:55:24 AM(UTC)
jeffinsgf
Check your specific model number, but I just went through this with mine, and it was the high-limit cut out -- different from the thermal fuse.
ammo1md
#4 Posted : Saturday, February 22, 2014 11:14:36 AM(UTC)
ammo1md
checked for power from circuit panel to dryer, all good. have replaced all electrical elements, and still doesn't heat. blower runs fine, cold air from exhaust. please help. model: EED4400EQ0 Whrilpool Dryer
Thanks.
Ed
fairbank56
#5 Posted : Saturday, February 22, 2014 11:48:09 AM(UTC)
fairbank56
Groups: Expert
Can't help if you don't answer the questions. When set to timed dry cycle, does the timer advance??? If it doesn't, then the motor switch is likely the problem. If it does advance, then the timer is likely the problem since you've replaced all other components in the heat circuit. The timers on these dryers are absolute junk and fail often.
Whirlpool W10185970 Timer - AppliancePartsPros.com
Eric
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
Belarus thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
