watsonwabbit69
#1 Posted : Thursday, June 19, 2014 10:41:14 AM(UTC)
watsonwabbit69
Symptom: Everything works but no heat
Troubleshooting: Element, Thermal Cut-off Fuse, High Limit T-Stat, etc. all have continuity, Good Blower airflow, door swithc is fine, timer rotates, 220v present to timer. Suspected timer issue (internal) after reading web reports. Inside of timer has a couple of blackened contacts that I suspect are the problem. When the blackened contacts are touching, I DO get continuity on the meter though. Wondering if they still break down under electrical load? I hate to buy a timer if perhaps blacked burnt looking contacts are normal on a 220v timer (W10185972). But I can't see any issues visibly elsewhere. ANy thoughts?
fairbank56
#2 Posted : Thursday, June 19, 2014 2:19:37 PM(UTC)
fairbank56
Groups: Expert
Most likely the timer. This piece of junk timer is used on the low end dryers. If you buy from APP and it doesn't fix the problem, you may return it.
Whirlpool W10185972 Timer - AppliancePartsPros.com
Eric
