Eddie365
#1 Posted : Saturday, October 17, 2009 12:35:57 PM(UTC)
Eddie365
Washer dryer combo. Has anyone encounter the following complaint.
WM3431HW / 503KW00093
Washer side works; However Dryer side won't work. When it comes to drying it do couple of things. first it will start to drain the it will start to get some water in but then display will go on and off, can heard the relay at main board coming on and off, red light on the board will turn on and off.
I have replace main board and display board.
All sensor for the drying parts were replaced.
heater and t-stat are good, heater comes on blower comes on.
can figure out why it does the washer load but not the drying.
sidfink43
#2 Posted : Sunday, October 18, 2009 6:54:05 AM(UTC)
sidfink43
Hi Eddie
Boy you have my sympathy. This is a very expensive machine, as you well know, and it should have lasted for years or decades without any problem given what you paid for it.
Unfortunately I have not worked on this machine (it is pretty unusual) and I doubt if any of the others who reply on this Forum have experience with the model (if you search for LG on the Forum you will see very few posts) so I am going to suggest you try other Forums. I hope you can find an aswer but I think at the end you will probably have to rely on an LG certified repair tech and having to pay for that visit and repair is adding insult to injury.
Good luck.
susanrm
#3 Posted : Wednesday, July 7, 2010 8:50:45 PM(UTC)
susanrm
I know this problem - it is due to lint buildup in the condenser duct. Someone posted a good how-to on cleaning it, but I don't have the link; google your heart out on the model number, and it should come up in a review. Basically the lint builds up in this plastic part to where the dryer just won't run. A design flaw. I found tons of lint in my newly-purchased used machine when I did a complete tear-down to fix what probably is a broken spider.
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
GE Washer Dryer Combo, clothes fell INSIDE how to get to them (Washer Repair)
by stilgarzero 10/27/2019 1:01:06 PM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 1:55:37 PM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire Stackable Washer Dryer Combo center (Washer Repair)
by megabyte5689 1/18/2016 2:56:21 PM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
Washer dryer combo acting up (Washer Repair)
by emshofk 11/26/2015 9:23:32 AM(UTC)
How to remove the tub from GE stackable washer dryer combo (Washer Repair)
by MSJORDAN 6/2/2015 11:42:26 AM(UTC)
Whirlpool Washer Dryer combo (Dryer Repair)
by TommyK 7/6/2014 7:29:56 AM(UTC)
Frigidaire washer dryer combo won't spin or drain (Washer Repair)
by MikeeD 1/24/2014 9:44:02 AM(UTC)
SE1000 washer dryer combo, dryer runs continuously no heat (Dryer Repair)
by mamasanders59 1/5/2014 1:41:28 PM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
replacing timer in washer dryer combo (Washer Repair)
by newlyretired 1/15/2012 9:30:36 AM(UTC)
washer dryer combos repair (Washer Repair)
by iblashaun 3/20/2011 8:37:38 PM(UTC)
by roscoe0807 12/18/2010 4:57:27 PM(UTC)
