josemeis
#1 Posted : Monday, February 3, 2014 11:37:45 AM(UTC)
josemeis
My dryer stop heating and when I Checked the heating element was damaged I replaced It and still didn't have heat. I kept checking and found a thermostat was bad. Change it and still no heat. I replaced and checked everything I could and still no heat. Can someone help me. Thanks.
#2 Posted : Tuesday, February 4, 2014 12:58:58 AM(UTC)
Parts for Maytag NED7200TW10 Dryer - AppliancePartsPros.com
Which thermostat did you replace?
There are two. (the hi-limit and the cut-off).
Check the thermistor.
Try getting into diagnostics to see if everything checks out.
As with any heat problem the first thing to check is the power.
The heating coil requires the full 240 volts, everything else will run off of 120 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
NED7200.pdf (1,696kb) downloaded 7 time(s).
You cannot view/download attachments. Try to login or register.
josemeis
#3 Posted : Wednesday, February 5, 2014 3:39:41 PM(UTC)
josemeis
Originally Posted by: denman Go to Quoted Post
If OK
If OK
I chequed the outlet and it have 240V also chequed the terminal at the dryer side and also have 240V. the cables look good. I turned off and on the brakers a couple of times and still no change, still no heat.
josemeis
#4 Posted : Wednesday, February 5, 2014 3:41:36 PM(UTC)
josemeis
also repleased both thermostats and the thermistor
#5 Posted : Thursday, February 6, 2014 1:51:57 AM(UTC)
If you check from the blue to the red on the motor's centrifugal switch you should read the heater resistance.
Check both reds as one will be the heater resistance and the other will be open (infinite resistance)
This double checks the wiring, heater and two thermostats.
If OK then you are left with two possibilities.
A bad control board or a bad centrifugal switch.
You can check the switch by shorting it's wires together and giving it a try.
Tape the wires co that they cannot short to anything else and cannot get caught in a moving part.
If you now have heat replace the motor.
If there is no heat I would replace the control board.
Amana washer shaking during spin, need help diagnosing (Washer Repair)
by Tryin2FixIt 9/21/2018 5:08:01 PM(UTC)
amana washer, grinding noise (Washer Repair)
by oilspotnm 8/11/2018 10:04:08 AM(UTC)
Amana fridgtor door not closing (Refrigerator & Freezer Repair)
by BillinArnold 7/20/2018 8:27:51 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Amana microwave blows fuse when opening door (Microwave Repair)
by txdutchman 1/28/2018 8:18:27 PM(UTC)
Amana Refrigerator TR25VW Leaking From Freezer (Refrigerator & Freezer Repair)
by Lamf77 11/29/2017 7:00:13 AM(UTC)
Amana Refrigerator (Refrigerator & Freezer Repair)
by pasjr 10/18/2017 8:42:26 PM(UTC)
Amana side-by-side water dispenser drip (Refrigerator & Freezer Repair)
by niffirg20 10/6/2017 4:43:52 AM(UTC)
Amana Front Loader Multiple Issues (Washer Repair)
by Lois007 8/27/2017 7:06:50 AM(UTC)
Amana washing machine trouble (Washer Repair)
by Freddy76 7/17/2017 2:47:07 PM(UTC)
Amana Upright Frostfree Freezer Issue (Refrigerator & Freezer Repair)
by ram5thwheel 7/15/2017 12:39:20 PM(UTC)
Amana fans stove not heating on bake, broil, or self clean (Oven Repair (including Ranges and Cooktops))
by Eyesy 6/18/2017 4:37:25 PM(UTC)
Amana Washer (Washer Repair)
by robert44483 6/17/2017 3:04:37 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
Amana AFB2534DEW cooling on & off (Refrigerator & Freezer Repair)
by gabrut 6/8/2017 8:46:03 AM(UTC)
