josemeis
#1 Posted : Monday, February 3, 2014 11:37:45 AM(UTC)
josemeis
My dryer stop heating and when I Checked the heating element was damaged I replaced It and still didn't have heat. I kept checking and found a thermostat was bad. Change it and still no heat. I replaced and checked everything I could and still no heat. Can someone help me. Thanks.
#2 Posted : Tuesday, February 4, 2014 12:58:58 AM(UTC)
Parts for Maytag NED7200TW10 Dryer - AppliancePartsPros.com
Which thermostat did you replace?
There are two. (the hi-limit and the cut-off).
Check the thermistor.
Try getting into diagnostics to see if everything checks out.
As with any heat problem the first thing to check is the power.
The heating coil requires the full 240 volts, everything else will run off of 120 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
NED7200.pdf (1,696kb) downloaded 7 time(s).
josemeis
#3 Posted : Wednesday, February 5, 2014 3:39:41 PM(UTC)
josemeis
Originally Posted by: denman Go to Quoted Post
If OK
If OK
I chequed the outlet and it have 240V also chequed the terminal at the dryer side and also have 240V. the cables look good. I turned off and on the brakers a couple of times and still no change, still no heat.
josemeis
#4 Posted : Wednesday, February 5, 2014 3:41:36 PM(UTC)
josemeis
also repleased both thermostats and the thermistor
#5 Posted : Thursday, February 6, 2014 1:51:57 AM(UTC)
If you check from the blue to the red on the motor's centrifugal switch you should read the heater resistance.
Check both reds as one will be the heater resistance and the other will be open (infinite resistance)
This double checks the wiring, heater and two thermostats.
If OK then you are left with two possibilities.
A bad control board or a bad centrifugal switch.
You can check the switch by shorting it's wires together and giving it a try.
Tape the wires co that they cannot short to anything else and cannot get caught in a moving part.
If you now have heat replace the motor.
If there is no heat I would replace the control board.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 12/25/2023 6:22:47 PM(UTC)
NTW4516FW3 Amana Top Loader Washer (Washer Repair)
by KMags 11/28/2023 4:52:44 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana fridge SX26VE door seals, hens teeth? (Refrigerator & Freezer Repair)
by Guest 8/31/2023 10:58:17 AM(UTC)
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
