proftod
#1 Posted : Sunday, January 19, 2014 1:31:59 PM(UTC)
proftod
Our one-year-old Samsung washer is leaking A LOT of water. I started it and 30 minutes later there was a red error code (the garment+ icon was lit up). I hit run, and almost immediately a lot (see above) of water came streaming across the floor from below the washer. I double checked all of the hoses and they were not wet so I am quite certain the issue is from within and below the washer.
Is it possible that a hose within the washer could be frozen?
Thanks for any help.
Todd
Samsung WA5451ANW
Support - Washers WA5451ANW/XAA | Samsung Washers & Dryers
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
