Our one-year-old Samsung washer is leaking A LOT of water. I started it and 30 minutes later there was a red error code (the garment+ icon was lit up). I hit run, and almost immediately a lot (see above) of water came streaming across the floor from below the washer. I double checked all of the hoses and they were not wet so I am quite certain the issue is from within and below the washer. Is it possible that a hose within the washer could be frozen? Thanks for any help. Todd Samsung WA5451ANW Support - Washers WA5451ANW/XAA | Samsung Washers & Dryers
