Joined: 7/5/2020(UTC) Posts: 0  Location: SOUTH CAROLINA
Hello, when my Duet washer WFW70HEBW0 is not in use, the short hose (where the water comes out) at 10:00 near the gasket, drips. Does anyone know what part needs to be replaced to stop the leak? I did not know if it was the inlet valve that had a worn gasket. It also leaks about a 1/3 cup in the front. This may by my door gasket. the unit is 6 years old and we use it hard with 4 kids. thanks Edited by user Sunday, July 5, 2020 2:29:22 PM(UTC)
| Reason: Not specified
