No power to G16FARXXY07 whirlpool refrigerator compressor. Replaced overload relay, both circuit cards, the freezer thermistor. 3n1 indicates compressor works good-makes cold air! What else is cutting the power out?
First of all, never use a 3n1 hard start on a compressor, will eventually blow it out. Second, check model #
i used them for ten years, they are a get by, but sometimes that was all they could afford. I always explained, that the three in one was a stop gap, and %99 of the time all they wanted was for the frige to last for a couple of more paydays.
