polkarandy
#1 Posted : Monday, January 6, 2014 5:55:42 PM(UTC)
polkarandy
We have a Frigidaire model # GLTR1670AS0 front load washing machine that does not fill on the first cycle (the wash cycle) on any of the settings. If I bypass that cycle by manually advancing the dial, it fills and runs normally through the remainder of the cycle. Is this likely a defective timer control or is there a fill solenoid that could be bad? Or something else I should look at? I haven't taken anything apart yet....not really sure where to start.
Randy
#2 Posted : Wednesday, January 8, 2014 6:07:21 AM(UTC)
Parts for Frigidaire GLTR1670AS0 Washer - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...df/Webster/134052900.pdf
[COLOR="Blue"]Is this likely a defective timer control[/COLOR]
Could be
[COLOR="Blue"]or is there a fill solenoid that could be bad?[/COLOR]
Depends on the cycle you are using.
If it does this on a cold/cold cycle then the valve is OK.
it it does this on a hot/cold cycle then it could be that the hot side of the valve is bad.
[COLOR="Blue"]Or something else I should look at?[/COLOR]
Could also be the temperature switch.
Odds are that it is the timer but this is just a guess.
To confirm this you would have to use a meter and check the timer and temperature switch contacts using the timing charts in the tech sheet to see if they are closing when they should.
polkarandy
#3 Posted : Wednesday, January 8, 2014 6:37:38 AM(UTC)
polkarandy
Thanks for the information and reply...I will get to work on testing it tonight.
Randy
polkarandy
#4 Posted : Wednesday, January 8, 2014 5:26:58 PM(UTC)
polkarandy
Thanks DENMAN...I did test the switch tonight an confirmed it is the timer switch, and will order a replacement. Thanks for your help.
Randy
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
Is it the timer switch? (Dryer Repair)
by Craig007 3/11/2012 6:17:37 PM(UTC)
Series 90 Washer Timer switch? (Washer Repair)
by apowers225 9/7/2009 10:47:28 AM(UTC)
How to replace Maytag Dryer timer switch? (Dryer Repair)
by tlhjax 1/23/2008 3:12:32 PM(UTC)
