I replace the thermal fuse thermal cutoff kit and push to start switch still wont start
Did you check the parts with a meter before replacing them of did you just replace them.
Does the drum light work? Does it turn off when the door switch is closed? |
THIS FORUM IS DEAD!!!!!!! |
