fvorees01
#1 Posted : Thursday, October 15, 2009 2:44:21 PM(UTC)
fvorees01
The estate dryer (Whirlpool) will not start. I've checked the fuse box and ensured the dryer was properly plugged in. The dryer has a push to start switch and the light is on inside the dryer. How do I fix this problem?
#2 Posted : Thursday, October 15, 2009 3:17:21 PM(UTC)
Replacement parts for TEDS840PQO models | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/d...0Sheet%20-%208528190.pdf
You will see a thermal fuse in the 4M line of the motor, this is an Item 7 in the "Bulkhead parts" section.
Unplug the unit, remove one wire from the fuse and check it with a meter.
Should be 0 ohms.
This is the easiest and safest way to check it.
The jiggery pokery method is:
Unplug the unit.
Remove the wires from the fuse and short them together.
Tape them up so they cannot short to the frame/case.
Plug the unit in and give it a try.
If blown replace ASAP as this is a critical safety device.
Give the interior a good cleaning, including the blower wheel.
Also check/clean your vent system.
These are the most common cause of the fuse blowing.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
