clarajj
#1 Posted : Monday, October 19, 2015 5:29:21 AM(UTC)
clarajj
I just bought this kenmore 100 series 60222. It doesn't not power on!!!
I've tested the voltage and that's good, the breaker is fine, no blown fuses. The only thing I haven't tried is a new power cord, but that's BRAND NEW also!!!
Someone help me!!
#2 Posted : Wednesday, October 21, 2015 2:32:40 AM(UTC)
Your model number is incomplete.
Sears numbers are usually 3 digits, a period and an additional 8 digits.
Below is how to check the power.
I am assuming it is an electric dryer.
It is the L1 to Neutral side of the line that runs the motor.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If all OK
check the door switch.
Also most units have a thermal fuse on the blower. Unplug the unit and check that it is 0 ohms.
Also some units have a belt switch down by the motor which also kills power to the motor if there is a problem with the belt.
