washer will not spin on my front loader how to change the belt
There Is An Oily Substance On The Drum Of The Washer. The Aggitator Has Been Popped Off And We Think It The Drive Belt Seal Model# Lwm353w Amana Is There An Easy Way To Get This Off?
To hawk, In order to access the belt you have to remove the rear cover. - The part number for the belt is AP3841228 Here are the break down diagrams for the Whirlpool washer Model GHW9100LW1Gene.
To kenfer, Most likely the hub & seal kit (#9 on the wash tub break down diagram) has to be replaced. It comes with the complete installation instructions. - The part number for the hub & seal kit is AP171986 Here are the break down diagrams for the Amana washer Model LWM353WGene.
