abacotc
#1 Posted : Monday, December 2, 2013 6:14:44 AM(UTC)
abacotc
Whirlpool Quiet Partner 1 not filling with water. This happened under "Normal" mode first. I was able to wash in "Pots & Pans" for about 6 months, but now it is happening in every mode. It will not fill with water. Comes on and makes noise but no water. Any ideas? Thanks in advance!
#2 Posted : Tuesday, December 3, 2013 12:48:06 AM(UTC)
Parts for Whirlpool DU1055XTSS2 Dishwasher - AppliancePartsPros.com
See the attachment for your tech sheet.
That the unit used to fill in one cycle type but not others points towards a bad control board, but I would do the valve checks just in case it is something weird.
Check that the float switch is being activated (closed)
Sometimes the float can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve when it should be filling.
If there is no voltage, check across the fill valve/overfill switch combo (wired in series)
If there is no voltage there, then the control board is probably toast.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
I would check the wires from the parts that go up to the control board for continuity, just in case it is a bad wire.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If all the above are OK then I would replace the control board.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
DU1055.pdf (245kb) downloaded 16 time(s).
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
GE Dishwasher not filling with water (Dishwasher Repair)
by shawnkocher508 10/31/2016 12:12:32 PM(UTC)
Ice maker not filling with water (Refrigerator & Freezer Repair)
by bdaddy711@aol.com 7/13/2016 6:00:46 PM(UTC)
KitchenAid Dishwasher not filling with water (Dishwasher Repair)
by njallison@juno.com 7/16/2015 5:58:31 PM(UTC)
KitchenAid Standalone Ice Maker Not Filling With Water After a Few Cycles (Refrigerator & Freezer Repair)
by jessep28 8/4/2014 2:58:30 PM(UTC)
Maytag Dishwasher not filling with water (Dishwasher Repair)
by icemanbryan 8/15/2013 5:43:03 PM(UTC)
Kenmore Elite Ice Machine not filling with water (Refrigerator & Freezer Repair)
by BrinsonServices 4/29/2013 6:25:15 AM(UTC)
Whirlpool Icemaker Not Filling With Water (Refrigerator & Freezer Repair)
by jgibby65 1/28/2013 2:13:27 PM(UTC)
KitchenAid Dishwasher - not filling with water (Dishwasher Repair)
by basaramaman 1/10/2013 5:44:20 AM(UTC)
by rcb 12/10/2012 2:57:55 PM(UTC)
Whirlpool GSS26C5XXY00 ice maker not filling with water (Refrigerator & Freezer Repair)
by amain 11/5/2012 12:35:22 PM(UTC)
Dishwasher makes humming sound but not filling with water & washing (Dishwasher Repair)
by lgscubagirl 9/21/2012 7:40:23 AM(UTC)
Ice Maker Not filling with water (Refrigerator & Freezer Repair)
by sooscreek 9/7/2012 12:24:44 PM(UTC)
icemaker not filling with water (Refrigerator & Freezer Repair)
by deli63 2/8/2012 5:10:25 PM(UTC)
