bullheadpond
#1 Posted : Thursday, November 21, 2013 3:01:06 PM(UTC)
bullheadpond
have e fridge with ice maker and water.About a year ago the ice maker quit working. i took the back off unpluged the electricalconnectors on the water valves and the one for the water which works s. reads 295. ohm the one for the ice maker reads 195. ohms. DOES that mean the valve is bad? \its the type that has one water line in and two lines out each line out has its own electrical plug?
Appliance Ninja
#2 Posted : Thursday, November 21, 2013 3:54:24 PM(UTC)
Appliance Ninja
Those readings do not indicate the valve coil is open, so we will need to do more testing. An easy test is to fill the ice maker manually and see if it dumps cubes in a few hours. If it does, the issue is likely with the valve or tubing. If it does not, the issue is likely with the ice maker itself. There are other tests, but this is a very easy way to get a general idea of where to start. Let me know if it dumps the cubes.
Water Dispenser not working but ice maker is still working (Refrigerator & Freezer Repair)
by Bobby-Houston 1/14/2019 1:01:20 PM(UTC)
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 1/12/2019 12:49:56 PM(UTC)
Kitchenaid Ksc24c8eyp02 fridge ice maker no voltage (Refrigerator & Freezer Repair)
by Speedreamz 12/21/2018 2:14:39 PM(UTC)
Ice Maker Whirlpool ED25PQXFW00 (Refrigerator & Freezer Repair)
by nassaubay 12/11/2018 7:52:00 AM(UTC)
KitchenAid ice maker - ice sometimes slides into reservoir pan rather than onto cutter grid (Refrigerator & Freezer Repair)
by thall88 12/7/2018 1:59:31 PM(UTC)
frigidiare ice maker replacement (General Talk)
by corvairbob 11/17/2018 4:35:06 AM(UTC)
New ice maker control module wattage difference (Refrigerator & Freezer Repair)
by bnezzy 7/22/2018 11:23:12 AM(UTC)
No power to ice maker (Refrigerator & Freezer Repair)
by BradC257 7/21/2018 9:32:03 PM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Samsung Ice Maker (Refrigerator & Freezer Repair)
by krupp 4/19/2018 2:24:58 PM(UTC)
Ice Maker Freezing up (Refrigerator & Freezer Repair)
by Margni 4/4/2018 3:10:49 PM(UTC)
Low voltage to ice maker (Refrigerator & Freezer Repair)
by ehorowitz 3/21/2018 12:56:38 PM(UTC)
Ice Maker Makes Ice but Does Not Dispense (Refrigerator & Freezer Repair)
by PhilRay 3/15/2018 8:53:23 AM(UTC)
Kitchenaide side by side Ice Maker issues (Refrigerator & Freezer Repair)
by Dedalus 2/27/2018 5:43:35 PM(UTC)
Frigidaire not supplying water to ice maker (Refrigerator & Freezer Repair)
by sascgcs 2/18/2018 2:25:16 PM(UTC)
