bullheadpond
#1 Posted : Thursday, November 21, 2013 3:01:06 PM(UTC)
bullheadpond
have e fridge with ice maker and water.About a year ago the ice maker quit working. i took the back off unpluged the electricalconnectors on the water valves and the one for the water which works s. reads 295. ohm the one for the ice maker reads 195. ohms. DOES that mean the valve is bad? \its the type that has one water line in and two lines out each line out has its own electrical plug?
Appliance Ninja
#2 Posted : Thursday, November 21, 2013 3:54:24 PM(UTC)
Appliance Ninja
Those readings do not indicate the valve coil is open, so we will need to do more testing. An easy test is to fill the ice maker manually and see if it dumps cubes in a few hours. If it does, the issue is likely with the valve or tubing. If it does not, the issue is likely with the ice maker itself. There are other tests, but this is a very easy way to get a general idea of where to start. Let me know if it dumps the cubes.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
