My washer will not drain. I took the pump out, cleaned it, lubed it and hooked it up to 120 vac on the bench, works good. I reinstalled it in the machine, it doesn't pump water. I checked the power and it has 120vac to it, I can hear it running, but it pumps no water. Water will drain thru the hoses when I put the end lower than the machine , so I know hoses aren't clogged. New pump is ~ $120, not sure if pump is problem. Any ideas? Thanks
Sounds like the impeller inside the pump is broken. See if you can have visual confirmation, but if not hook a hose up to it, stick the hose in a bucket of water and see if it pumps when you hook power up to it. That should be a confirming test.
