denmor1991
#1 Posted : Saturday, October 5, 2013 3:14:15 PM(UTC)
denmor1991
My washer will not drain. I took the pump out, cleaned it, lubed it and hooked it up to 120 vac on the bench, works good. I reinstalled it in the machine, it doesn't pump water. I checked the power and it has 120vac to it, I can hear it running, but it pumps no water. Water will drain thru the hoses when I put the end lower than the machine , so I know hoses aren't clogged. New pump is ~ $120, not sure if pump is problem. Any ideas? Thanks
sidfink43
#2 Posted : Sunday, October 6, 2013 3:31:53 PM(UTC)
sidfink43
Sounds like the impeller inside the pump is broken. See if you can have visual confirmation, but if not hook a hose up to it, stick the hose in a bucket of water and see if it pumps when you hook power up to it. That should be a confirming test.
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
GE washer won't drain for large or normal loads. Only very small. (Washer Repair)
by joel_m_michael 1/7/2012 2:47:02 PM(UTC)
Ge washer won't drain (Washer Repair)
by dk2010 6/22/2011 5:49:16 PM(UTC)
GE washer won't drain (Washer Repair)
by deplayerjr 7/16/2009 6:53:22 PM(UTC)
GE Washer won't drain (Washer Repair)
by BALIPS 5/21/2009 6:50:09 AM(UTC)
My GE washer won't drain (Washer Repair)
by Crsmom00 9/8/2008 3:58:23 PM(UTC)
GE washer won't drain Need help quick!!! (Washer Repair)
by meea 8/31/2007 10:07:33 AM(UTC)
