I have a Frigidaire Front Load Washer FTF630AS0
It doesn't spin or, better put, the motor doesnt turn and the timer doesn't advance. Having spent much time reading this forum, watching YouTube videos, and testing the machine, I was confident that the Motor Control Board need to be replaced.
I used sear parts direct and the board is listed as 131770700 with Substitution: 134149220
I bought a replacement on ee bai listed as 131770700
Installed the replacement board and the motor works and the timer advances but the cycle is out of whack. I had to manually advance a few times until it did a final spin then filled with water again then stopped.
I think I got the wrong board but wanted some expert advice before proceeding.
The original board has PN: 221870020 and Frigidaire NO: 134058400
The replacement board has PN: 221870021 and Frigidaire NO: 134285700
Is there anyway to cross reference the sear parts direct numbers with the numbers I see on the parts?
Any advice would be appreciated
