AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Front Load Washer not completing full cycle
I have a Frigidaire ATF 7000eg0 front load washer. It washes, but then it just sits there and will not go through the rinse and spin cycle. I have to put it through another wash cycle without laundry detergent to rinse the soap out. Sometimes it takes several tries to get it to go through another wash cycle. To drain water out, I put it on spin only. Pump takes water out and sometimes it will spin fast, sometimes slow, and sometimes not at all. I never completes spin cycle, it stops with about 1 -2 minutes.
I have replaced door lock switch, motor control board, control (part 134558200), and the main control board. Taken complete apart, even taken the tube assembly out to remove sock, check all hoses to and removed socks. Thing still does not work correctly. :mad:
Wow, that should have fixed it. It may be that the pump needs to be replaced, so try that. If you buy from this site and the pump does not fix things you can return it.
I'll try the pump. Is there anything else that may be causing the problem. Now I can't get it to go through a wash cycle. Runs water for about 2 seconds, then stops. The pump also doing the same thing. Runs about 2 seconds and stops.
Washer Repair
