fredpeterson543
#1 Posted : 12 years ago
fredpeterson543
Hello Friends,
Thank you for coming in this thread.
There is a QUESTION for you.
Dryer repair question?
I have a 2 year old dryer that I turned on one day and it immediately stopped after 5 seconds. I cannot start it by turning the switch but I can start it by hand by spinning the drum with the door button pushed down (it works I swear). Once I get it running by hand it still does not produce heat.
It is not a fuse or outlet problem because it can still run.
Does anyone have any idea of what part needs to be replaced? I think it might just need a new switch because it not only starts the drum but it also turns on the heating element. This would explain why it does not heat up when I get it going by hand.
Web Designing Companies in Delhi
[URL="http://www.ewebtech.in/SEO.php"][/URL]
#2 Posted : 12 years ago
[COLOR="Blue"] I think it might just need a new switch because it not only starts the drum but it also turns on the heating element. This would explain why it does not heat up when I get it going by hand.[/COLOR]
I agree with you that it could be the centrifugal switches on the motor.
One thing to check is that the motor is not clogged solid with lint.
This can stop the mechanical device in the motor from activating the switches.
Dryer Repair Again and Again (Dryer Repair)
by Guest 3 years ago
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 3 years ago
Dryer repairs (Dryer Repair)
by P3FE 3 years ago
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 5 years ago
Dryer Repair Issue (Dryer Repair)
by jdharrin 6 years ago
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 7 years ago
Dryer repair Help! (Dryer Repair)
by Hah45 8 years ago
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 9 years ago
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 9 years ago
Dryer Repair (Dryer Repair)
by sotomargie 9 years ago
Dryer repair (Dryer Repair)
by dchurch 10 years ago
by jaybick 10 years ago
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10 years ago
by Tom Campion 11 years ago
by kencorey281@gmail.com 11 years ago
