1. Initial problem was the burner igniters would fire even if all the switches were off. Even occurred in the middle of the night. 1.1 Recommendation to replace burner on switches. 1.2 Replaced two switches and system igniters were off for one hour then the problem returned..
2. Replaced igniter module. 2.1 Igniters no longer spark when all switches off, however, igniters now spark continuously when any burner is on.
Any suggestions?
The ignitors all light up no matter what burner you use that's normal operation of a gas stove. Now if it's sparking after something is lit then you have a wire harness issue more then likely going to your burners. Find the tech sheet on your unit and look at the wire schematic or go to this website and find your schematic.....Good luck http://www.manualowl.com/
