Broiler igniter reads 93ohms... I found only 40vac going to igniter. Is the problem the gas valve controller??? Oven bakes, but does not broil.
whats the ohms and voltage going to bake ignitor?
Bake igniter reads 88ohms and 120vac, when igniting. This one works fine.
