sailgwk
#1 Posted : Tuesday, September 3, 2013 9:58:57 AM(UTC)
sailgwk
1. Initial problem was the burner igniters would fire even if all the switches were off. Even occurred in the middle of the night.
1.1 Recommendation to replace burner on switches.
1.2 Replaced two switches and system igniters were off for one hour then the problem returned..
2. Replaced igniter module.
2.1 Igniters no longer spark when all switches off, however, igniters now spark continuously when any burner is on.
Any suggestions?
HumboldtRepairMan
#2 Posted : Tuesday, September 3, 2013 5:27:44 PM(UTC)
HumboldtRepairMan
The ignitors all light up no matter what burner you use that's normal operation of a gas stove. Now if it's sparking after something is lit then you have a wire harness issue more then likely going to your burners. Find the tech sheet on your unit and look at the wire schematic or go to this website and find your schematic.....Good luck
http://www.manualowl.com/
Igniter on when turned off but not when on Lite (Oven Repair (including Ranges and Cooktops))
by curtwitt 6/16/2012 4:36:46 PM(UTC)
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 4/28/2011 8:47:52 AM(UTC)
How do i install a igniter on a Tappan mgf355bgwb gas oven (Oven Repair (including Ranges and Cooktops))
by lucas8026@comcast.net 12/30/2010 6:38:07 AM(UTC)
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
Replacing round igniter on Kenmore gas oven (Oven Repair (including Ranges and Cooktops))
by techmonster 4/24/2010 11:55:57 AM(UTC)
igniter on 2 of the burners doesn't spark (Oven Repair (including Ranges and Cooktops))
by bigchevy79 8/24/2009 6:57:21 AM(UTC)
How to replace igniter on Thermador prds366 (Oven Repair (including Ranges and Cooktops))
by mwynia 1/17/2009 12:11:06 PM(UTC)
oven broiler igniter only geting 40vac (Oven Repair (including Ranges and Cooktops))
by donniebraso 11/14/2008 6:17:47 PM(UTC)
Install oven igniter on tappan range (Oven Repair (including Ranges and Cooktops))
by jtfore 10/31/2008 7:07:10 AM(UTC)
Selecting Lite on any burner starts igniter on RF ONLY (Oven Repair (including Ranges and Cooktops))
by cberrya6e 9/29/2008 9:51:47 AM(UTC)
How to test the oven igniter on gas range (Oven Repair (including Ranges and Cooktops))
by westje 6/25/2008 10:10:48 AM(UTC)
how to replace igniter on thermador gas grill (Oven Repair (including Ranges and Cooktops))
by cosomactoo 9/13/2007 9:24:23 AM(UTC)
