Dryer stopped in middle of cycle and wont start back. I took back off and cleaned vent out nothing blocking it and it still wont start. when u push start button it will hum but when you let go of button it does nothing no humming no anything.. Please help i am trying to fix this myself i am about defeated....:mad:
Here are your parts Parts for Whirlpool LER3624EQ0 Dryer - AppliancePartsPros.comSounds like the motor is not starting. Try turning the drum in the corret direction. It should turn fairly easily. You may want to try this on a couple other dryers to get a feel for it. If it does turn fairly easily yhen odds are that you need a new motor. |
THIS FORUM IS DEAD!!!!!!! |
