SANMANNANCY
#1 Posted : Sunday, August 25, 2013 11:40:42 AM(UTC)
SANMANNANCY
Does Anyone Have Any Info On What Horrible Sound During Spin Cycle Can Be? Sounds Like Jet Engine. Everything Else Works Fine. Wondering If Worth Trying To Repair Or Just Buy New One. It Is An Lg Washer. 5 Yrs Old No Warranty On Labor Only Motor And Tub.
HumboldtRepairMan
#2 Posted : Sunday, August 25, 2013 12:54:11 PM(UTC)
HumboldtRepairMan
Typically that noise like a low flying airplane is your bearing out on the tub or the spider is damaged. Here's a couple video's to help you determine it. Easy way to tell is grab the drum (metal part) and the tub the plastic part surrounding it and see if you have alot of free play you shouldn't have barely any movement bringing those pieces closer to each other. Also check in the rear of the unit see if you notice any rust or water seeping out the rear of the tub where the shaft comes out. If so your bearings or seal are shot and your machine needs a complete rebuild
Secret Samurai Technique For Checking The Drum Bearings In A Front Load Washer - YouTube
Kenmore front load washer with a bad tub bearing - YouTube
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
