RFrick
#1 Posted : Thursday, August 15, 2013 4:12:10 AM(UTC)
RFrick
My Maytag dryer just stopped working mid cycle. There is power going into the dryer.
#2 Posted : Thursday, August 15, 2013 7:39:36 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Maytag HYE2460AYW Dryer - AppliancePartsPros.com
Could be that the thermal fuse blew (Item 5 in the Heater Parts section).
You should check to see if you can find out why it blew.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the fuse.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
Our dryer stopped working after we got a new water heater (Dryer Repair)
by MKemp 4/8/2018 2:26:53 PM(UTC)
Kanmore Dryer Stopped Working (Dryer Repair)
by willow5000 2/21/2014 10:37:25 AM(UTC)
admiral dryer stopped working (Dryer Repair)
by Court 3/16/2013 12:41:47 PM(UTC)
Whirlpool Duet Dryer stopped working (Dryer Repair)
by bobbijo 11/25/2011 1:28:04 PM(UTC)
Dryer stopped working-timer still works. (Dryer Repair)
by T Krol 11/20/2011 12:32:56 PM(UTC)
Whirlpool dryer stopped working LER7646EQO (Dryer Repair)
by mcf57 10/14/2011 4:26:32 AM(UTC)
Whirlpool Dryer stopped working (Dryer Repair)
by jjgundy 8/24/2011 12:03:40 PM(UTC)
Timer on Whirlpool Dryer stopped working (Dryer Repair)
by J Kreimer 2/5/2011 1:27:21 PM(UTC)
by julios 10/24/2010 12:15:47 PM(UTC)
Dryer stopped working mid cycle, won't restart (Dryer Repair)
by Set 12/10/2009 9:51:39 AM(UTC)
Help my dryer stopped working mid cycle (Dryer Repair)
by leladees 11/10/2009 8:25:32 AM(UTC)
Dryer stopped working completely (Dryer Repair)
by pns 10/24/2009 4:29:21 AM(UTC)
Roper Dryer stopped working (Dryer Repair)
by dhud64 10/11/2009 5:20:43 AM(UTC)
Kenmore dryer stopped working (Dryer Repair)
by ElizabethGville 8/23/2009 4:45:01 AM(UTC)
by aich75013 3/11/2009 6:52:15 AM(UTC)
