Our Roper dryer stopped in the middle of a cycle. I have checked the incomming power and power at the terminal block. I have continuity at the start switch but do not understand how to test the timer. I don't see anything obvious such as burnt wirers etc. Anmy help would be appreciated! DH
I attempted to check the timer by unplugging all the wires and testing each termnal one by one with the black lead from my DMM and red lead to each terminal one at a time. If I'm doing this right, it seems that the OR and WB terminals had no readings at all. I'm guessing this is the problem?
More info in problem: The wife also says that the dryer has also been continuing to run if you open the door.
