Here are your parts includes a wiring diagram.
Replacement parts for ADMIRAL ADE9005AGW | AppliancePartsPros.comIf you just looked at the breaker try flipping it off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it with a meter.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral should both be 120 volts.
Next check the door switch to make sure it is being activated.
Better yet check it with a meter.
Next check the thermal fuse Item 6 in section 1 "Base" with a meter should be 0 ohms.
The jiggery pokery method is:
Unplug the unit.
Short the wires together
Tape them up so they cannot short to the frame.
Plug it in and try it.
If it runs replace the fuse ASAP as it is a critical safety device.
Note you can also use the same method for the door switch.
If the fuse is blown the most common cause is low air flow.
Clean the interior of the unit including the blower wheel.
Also clean and check your vent system.
