James D R
#1 Posted : Tuesday, July 30, 2013 1:14:45 PM(UTC)
James D R
I'm getting a lot of frost build up and want to check the defrost timer but I can't find it. Does anyone know where it is located? Our freezer seemed to work fine but the fridge would not get colder than 50 degrees. I pulled off the back panel of the freezer and found that the foam block that directs the air from the freezer to the fridge was locked up with ice. It is now working again but we are getting frost in our freezer.
James
HumboldtRepairMan
#2 Posted : Tuesday, July 30, 2013 3:38:41 PM(UTC)
HumboldtRepairMan
Your model number is incomplete should have alot more digits and yes model number does matter...most defrost timers are inside the top of the refrigerator on the top where the light fixture is....typically it's 4-6 1/4" screws you have to take out........to test it there's usually a slot in that cabinet which allows you to take a small screwdriver and advance the defrost timer slowly and look at the defrost heater in the back of the freezer area, force it into defrost you'll usually hear a click and you'll see the bottom of the evaporator start melting ice......if you don't you have a defrost timer or bi metal/thermistor or defrost heater problem typically
James D R
#3 Posted : Tuesday, July 30, 2013 4:12:20 PM(UTC)
James D R
I will have to look elsewhere for the model number. That is all the sticker on the back said.
James D R
#4 Posted : Tuesday, July 30, 2013 4:15:03 PM(UTC)
James D R
I did Pull the light fixture down and was unable to find that advancements screw.
HumboldtRepairMan
#5 Posted : Tuesday, July 30, 2013 4:17:09 PM(UTC)
HumboldtRepairMan
Unless you have a part number on the part you need if you don't have a complete model number you won't be able to find a part for it most likely.....Check your owners manual also but Ge series for this type should have a 13 digit alpha numeric model number. Good luck. It should be inside the fridge on the right of left or in the back of the unit.
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
