When you turn the Machine on it starts to agitate before the water begins to fill the tub. If I hand fill the tub and then start the washer all the cycles work fine.
Groups: Expert
Open the control panel and on the back of the fabric softener switch, unplug the two wire harness plugs and the pressure hose. Blow into the hose to make sure it's clear. If it isn't, you will have to remove the cabinet and unplug the hose from the air dome on the lower right rear of the tub to clean the gunk out of the hose and air dome. Plug hose and harness connectors back in and try it. If it still does the same thing, replace the switch. Whirlpool W10292584 Switch-Sen - AppliancePartsPros.comEric
Originally Posted by: fairbank56 Open the control panel and on the back of the fabric softener switch, unplug the two wire harness plugs and the pressure hose. Blow into the hose to make sure it's clear. If it isn't, you will have to remove the cabinet and unplug the hose from the air dome on the lower right rear of the tub to clean the gunk out of the hose and air dome. Plug hose and harness connectors back in and try it. If it still does the same thing, replace the switch. Whirlpool W10292584 Switch-Sen - AppliancePartsPros.comEric Thanks for the great advice. You're awesome. Don
