donvd
#1 Posted : Sunday, July 28, 2013 5:17:57 PM(UTC)
donvd
When you turn the Machine on it starts to agitate before the water begins to fill the tub. If I hand fill the tub and then start the washer all the cycles work fine.
fairbank56
#2 Posted : Sunday, July 28, 2013 5:49:21 PM(UTC)
fairbank56
Groups: Expert
Open the control panel and on the back of the fabric softener switch, unplug the two wire harness plugs and the pressure hose. Blow into the hose to make sure it's clear. If it isn't, you will have to remove the cabinet and unplug the hose from the air dome on the lower right rear of the tub to clean the gunk out of the hose and air dome. Plug hose and harness connectors back in and try it. If it still does the same thing, replace the switch.
Whirlpool W10292584 Switch-Sen - AppliancePartsPros.com
Eric
donvd
#3 Posted : Tuesday, July 30, 2013 5:36:20 AM(UTC)
donvd
Eric
Thanks for the great advice. You're awesome. Don
Maytag washer problem (Washer Repair)
by tom luse 5/9/2013 8:12:39 AM(UTC)
by AFTERTHOUGHTS 7/28/2012 7:56:54 AM(UTC)
maytag washer problems (Washer Repair)
by djv106 9/24/2011 7:40:00 AM(UTC)
by SAYRES 9/11/2011 5:52:04 AM(UTC)
by cherylted 8/8/2011 9:29:34 AM(UTC)
by cherylted 5/26/2011 1:42:36 PM(UTC)
Maytag Washer Problems (Washer Repair)
by Jim Fedewa 2/18/2011 5:01:40 AM(UTC)
Maytag Washer Problem (Washer Repair)
by richard levy 2/20/2010 9:09:27 AM(UTC)
Maytag Washer problem (Washer Repair)
by redouse 1/15/2010 4:08:34 AM(UTC)
maytag washer problem (Dishwasher Repair)
by nowash 4/25/2009 3:02:25 PM(UTC)
by parker4628 3/18/2009 4:49:01 PM(UTC)
by Mike B 8/28/2008 1:44:12 PM(UTC)
