When I have the washer's water setting on oversize, water will leak ou from the top of the tub. I took the access panel off the back and could see the water coming down the sides from the top. HELP-problem 1
Problem 2- the clothes are not as dry at the end of spinng as they used to be. HELP
Originally Posted by: Jim Fedewa When I have the washer's water setting on oversize, water will leak ou from the top of the tub. I took the access panel off the back and could see the water coming down the sides from the top. HELP-problem 1
Problem 2- the clothes are not as dry at the end of spinng as they used to be. HELP How do I replace the tub seal on my PAV2360AWW Maytag washer
