Jim Fedewa
#1 Posted : Friday, February 18, 2011 5:01:40 AM(UTC)
Jim Fedewa
When I have the washer's water setting on oversize, water will leak ou from the top of the tub. I took the access panel off the back and could see the water coming down the sides from the top. HELP-problem 1
Problem 2- the clothes are not as dry at the end of spinng as they used to be. HELP
Jim Fedewa
#2 Posted : Tuesday, March 1, 2011 4:35:11 AM(UTC)
Jim Fedewa
How do I replace the tub seal on my PAV2360AWW Maytag washer
maytag washer problems (Washer Repair)
by djv106 9/24/2011 7:40:00 AM(UTC)
by SAYRES 9/11/2011 5:52:04 AM(UTC)
